Worked on the crush sleeve eliminator spacer first thing this morning.
Used a piece of aluminum block as a flat surface to sand the spacer flat.
Then got back to installing the gears. I added 0.002" of shims on the gear side which tightened up the backlash to 0.003". Carl wants it between 0.002-.003" so I should be good.
Coast side which is the drive side for this axle.
Drive side which is the coast side on this axle.
I think I'm done but will wait for input from others who setup gears more often than me.
