GoldCountry
Say more please.
If OD = Over Drive, I'm a tad lost, explain.
- Patrick
They are an electronically controlled overdrive/underdrive unit. In other words, two gear ratios that can be engaged or disengaged on the fly. The only thing I’m not sure of is if a Gear vendors or a similar two speed will give you enough of a gear split to make it useful to you. If I remember correctly, they are available in married and divorced units.
Though, now that I am saying this out loud in a voice to text situation, I am realizing this is not a very feasible idea in a TJ due to the short wheelbase.
I was thinking you would be able to eliminate the transmission altogether and attach the overdrive unit to the rear output of the transfer case giving you a freeway gear for 2wd situations.
I believe the gear vendors overdrive would have a lower weight and more compact form factor, as well as less rotational mass. Though, you would need an adapter from the motor to the transfer case.
Edit: maybe it’s possible to put in between the motor and the transfer case to give you a Gear split in both 2wd and four-wheel-drive.
