STICKY Wrangler TJ Factory Specifications
Chris, I believe the passenger side airbag deactivation switch was only installed on vehicles that didn’t come with a rear seat.
Reactions: bedhed
I always wondered about that. Only some of them have the passenger airbag deactivation switch. I thought maybe it was a factory option or something.
Fantastic information, I think what you have compiled is better that Wikipedia, thank you so much.
For anyone reading these posts who might wonder what there jeep was originally built with, engine, axles, gearing,
on down to seat material and color along with whether the the gas cap was tethered or not can find the original
build sheet that jeep used on the assembly line at:
https://www.jeep.com/webselfservice/jeep/index.html
When you go to that site you need to find the area on the left labeled "Your Vehicle", beneath that find and select
"equipment listing". The screen will change and offer a place to enter your VIN number. Do that and press "search".
You will receive a file in your download folder that you simply rename with the file extension "PDF" Open it
and find everything you always wanted to know about your jeeps secret history and inner workings. An eye opener.
Are you seeing a diff page than I am? I cannot find a place to put in my VIN and the previous links do not work/under maintenance.
Thank you @jodomcfrodo ..... I finally got it to work. I had to for some reason type it in a separate google search, then copy & paste the VIN # replacing yours. Now I can tell what gear ratio I have & a few other things. This is pretty accurate I would assume?
Reactions: FaithG
This link should be added to the top. That's the best maybe only way to find what all your own factory options were. A treasure trove of info.
Reactions: FaithG
Lot’s of great info here! I know that I’ve seen this somewhere but I can’t find it now. What are the stock bumper heights? Do they differ from year to year? Is Rubicon package different from others and what about Rubicon Unlimited? Thanks!
I seem to having the same issue here. I am unable to retrieve the build sheet for my Jeep. I’ve used the link and replaced your vin with mine and it says “no records found corresponding to the vin provided”. Is this site still functional?
Here is the link to my search.
https://www.jeep.com/webselfservice/BuildSheetServlet?vin=1j4fa49sx5p347427
https://www.jeep.com/webselfservice/BuildSheetServlet?vin=1J4FA49SX5P347427
Have to use capital letters in the VIN
Reactions: dschwes
Curious about the differences in length between back of the front wheel well and the front of the wheel well between the LJ and TJ. Looking for replacement rock sliders and there's confusion. I was told the only addition in length was behind the rear wheel well - they added length there. Any help would be appreciated.
