I also agree with what @Jerry Bransford said early in this thread. Personally am not a fan of these types of additives as they typically add to other challenges later in the vehicle's life.
In an Ideal world we would all have had a TJ from brand new 8 miles on the clock, So respectfully many owners have no idea how their TJ was serviced and used V abused so I respect your commentsOnly time to add a stop leak is right before you plan to sell the vehicle. Some are seal conditioners, and soften the rubber, some are a thick goo that may or may not blend with the oil, and seek out any small hole to fill... passageways included.
High mileage oil is designed to keep the seals conditioned and working smoothly. I will continue to use high mileage in my jeep, we have had the Jeep since delivery in 2005 (new with 8 miles on the clock) and plan to pass it on to our 8 year old. Have been using the high mileage oil since 100k miles, and other than the rear pinion seal finally giving out this summer (130k miles) the Jeep doesn't drip a drop of oil.
Have you experience in RMS additive? Seems to me its only putting in what's in High Mileage oil anyway!I also agree with what @Jerry Bransford said early in this thread. Personally am not a fan of these types of additives as they typically add to other challenges later in the vehicle's life.
That's what I always do.Personally I would use Blue Devil RMS leak and drive it in, what have you got to loose? you have new oil in it already and if the Blue Devil doesn't work then change to Conventional.
I bought my one owner Rubi from a retired Air Force guy who was anal with the records he kept from the first oil change until he sold it to me. It makes absolutely no difference in what's going to happen to a used Jeep, regardless of mileage. It's just luck in most cases.So respectfully many owners have no idea how their TJ was serviced and used V abused so I respect your commentsbut I have no idea who was driving my TJ before me so I like others are looking for solutions to problems that may or may not be actual problems!
Synth blend will not cut it for what you are looking for! 10w is what you need 5w is too thin 5W you would choose winter oil in Alaska or Siberia not NY.I'm convinced! I'm going to try the high mileage oil asap
@Jerry Bransford Jerry it seems like most high mileage oils are syn blend, ie Castrol, Valvoline Maxlife, etc. I know you said conventional though. Thoughts on a syn blend if its "high mileage"?
I noticed the leak after I used BG MOA additive along with conventional oil after hearing a mechanic on a local talk radio show raving over the product. I'm afraid that is what caused this as it never leaked before using that additive. I have since switched to just plain oil syn blend. I still see a small leak after that. Part of problem is I don't drive the jeep that much as it is not a daily driver & it's my summer "fun" vehicle.
I see another product called AT-205 with even better reviews. I'm leaning towards trying it even though most of these additives say it has to be driven for a while before it starts working.
Not Jerry, but I ended up finding High Mileage conventional oil at Advance Auto Parts under the “Fram” label. Everything else was a blend.I'm convinced! I'm going to try the high mileage oil asap
To sell a vehicle with additives put in just to get a sale is the reason I do not trust any PO.
Pennzoil makes a good engine oil too.I used Pennzoil's conventional High Mileage oil on my last change. It has reduced my leak to almost nothing.
@Jerry Bransford , am I understanding this correctly? Valoline 10w-30 High Mileage (in the red bottles) are 100% conventional? But other weights are not?NAPA's engine oil is made by Valvoline and they have a High Mileage conventional 10W-30. https://www.napaonline.com/en/p/NOL75300?impressionRank=2
The information confirming it's a conventional was a little sketchy so I actually called Valvoline who confirmed the 10W-30 version is indeed a 100% conventional. The Valvoline rep confirmed their non-10W-30 versions are blends or synthetics.
No, only the NAPA 10W-30 High Mileage is 100% conventional. Valvoline no longer brands that combination except for what they make for NAPA.@Jerry Bransford , am I understanding this correctly? Valoline 10w-30 High Mileage (in the red bottles) are 100% conventional? But other weights are not?
If so, great, that’s what I use and never was clear on if it was true conventional or a blend.
Ok, I see, just the NAPA. Thank you.No, only the NAPA 10W-30 High Mileage is 100% conventional. Valvoline no longer brands that combination except for what they make for NAPA.
