For you guys wanting weather proof speaker pods, check this out. I copied from the RZR Forum that I am a member on...
I wanted some music for the trails but considering how much some of these systems cost I decided to go the less expensive route. Here's what I used
-Plye hydro 2ch amp(iPhone as music source) comes with a dash mounted volume control, waterproof phone pouch, and all wires.
-note many reviews talk bad about this amp lacking power but there's a clear rubber cover on the side that allows you to turn up the gain and let me tell you, when turned up my neighbor two houses down can here my speakers loud and clear! Not bad for $45!! It plays loud over all engine and trail noise!!
2-6" PVC pipe end caps w/1.5" of 6" pipe cut and glued into the cap then cut off smooth
2-6.5" mtx marine speakers(best fit)
24' of marine black 18ga speaker cable
Stainless bolts to attach to cage w/washers, lock nuts and rubber bushing(between PVC and cage)
Maybe this will help someone looking to do a budget speaker in stall
View attachment 22921 View attachment 22922 View attachment 22923
