I can see that! haha
@JMT has compiled a great list of better alternativesBut it is rugged ridge. Any better alternatives?
Thanks thats a good link@JMT has compiled a great list of better alternatives
https://wranglertjforum.com/threads/rock-sliders-rocker-guards-guide.8704/
Likely factory Rubicon sliders because that is a Rubicon.Which is the rocker guard of the Red TJ in the banner? any links?
I was not aware that Rubicon had stock sliders. Not many Rubicons around here. Actually not even one.Likely factory Rubicon sliders because that is a Rubicon.
It's more of a light duty rocker guard than a slider.I was not aware that Rubicon had stock sliders.
Better check the vin, you can buy those stickers.Likely factory Rubicon sliders because that is a Rubicon.
There's two different ones: the "enhanced" rocker which has a bar that sticks off and the rubicon one, which is diamond plate. Neither is super thick, however, so if you come down on them hard you'll find some bends in the tub, even more-so if you have the ones with the added lever.I was not aware that Rubicon had stock sliders. Not many Rubicons around here. Actually not even one.
Remind me where the VIN is drawn on the Jeep.Better check the vin, you can buy those stickers.
Yours might be a bit more confused than the rest of ours...Remind me where the VIN is drawn on the Jeep.
This is some valuablle research right here@JMT has compiled a great list of better alternatives
<GASP> you posted something other than Savvy!If you want the same look as the Rubicon but you don't want the diamond plate tin foil they are made of that's exactly what UCF sells. Same deal except 3/16" steel. It uses the same mounting holes and is lower than most of the other options out there just like the factory guards.
That crap never stops being just that, crap.<GASP> you posted something other than Savvy!
