Power Tools: Battery Power vs Air Compressor
I may indeed give one a try as even I'll admit that cordless is better when it comes to screwdrivers - but I have yet to find one that will both last more than a couple of years, AND have the strength to drive a screw into hard wood. So I end up using a regular drill. Hell, one time a situation was so bad that I ended up using the afore mentioned "Thor" to drive a couple. As always, it got the job done in quick order, but using that drill to drive screws is a lot like using an atom bomb to kill a fly!
Model/make suggestions?
Reactions: Zorba
Zorba - I'm curious how much you think the Milwaukee cordless tools and batteries weigh? I just weighed a few of mine:
M18 1/4" Impact Driver (#2760-20) - 2.3 lb (no battery)
M18 1/2" Drill (#2801-20) - 2.5 lb (no battery)
M18 CP2.0 Battery - .9 lb
M18 XC5.0 Battery - 1.6 lb
If you put the XC5.0 battery on the drill above, it's just over 4 lb, and the balance in hand is very good. I'm curious how that drill above compares in weight, and I know it doesn't balance in hand as well with all the weight on one end of the handle...
I only use my tools nights and weekends because my day job is at a desk, but I do a LOT of weekend work with these, and I would say once every 3-4 weeks I swap a battery out for the most routine stuff like maintenance work. However, there are certain tools that do eat up the amp-hours, usually when fabricating. Cutting with a recip saw, jig saw, or cutoff wheel, or drilling big holes can require multiple batteries to do a job. For me, the convenience of not dealing with a cord trumps the few battery changes I have to do.
I went out and weighed a couple of mine. The little 1/4" drill ("Elmer's Drill") is 2.1 lbs! Realizing that isn't a fair apple-to-apple comparison, I grabbed the DeWalt hammer drill. It was exactly 1 lb heavier.
I hear you about balance - and that certainly makes a difference when driving screws. Doesn't really matter that much when drilling holes. Still more weight (and expense!).
Maybe its because I'm an old fart now, but I don't grok why you guys find cords such a PITA - unroll the cord at the beginning of the day, roll it back up at the end of the day or end of the job. Plug in once, boom done.
If you get an M12 Milwaukee then you can also use the batteries in your Milwaukee heated jacket. But maybe you don't need that in Florida
Reactions: toximus and Zorba
Get an M18 Milwaukee. Part of it is the screw your using too...but My OLD (OG milwaukee) 18V will drive 5/16 x 6" long Grex Timber Fasteners into wet landscape timbers without issue. No issues with "construction" fasteners into Ash or Oak either. It helps to predrill...but more to keep the wood from splitting vs the driver not having enough torque.
The way the impact works is just so much better than constant torque. Like @mrblaine said above...Try driving screws one handed above your head and not strip out heads with a drill...You can do it all day long with an impact driver...
Reactions: Zorba
I'm surprised on the weights. My two brothers and I did not fight over my late father's (he's been gone almost 20 years) power tool collection - they are still in my mother's basement. Some of those old all-metal Craftsman power tools could suffice as anchors!
Also, I don't think it's because you're an old fart - I don't think I'm too far behind you. It's just a difference of opinion.
Regarding cordless recommendations - as I said, I'm a strong Milwaukee fan. I don't buy DeWalt anymore due to the motor problems I had. However, that was about a decade ago, so they may be better now. There are other cordless brands, but Milwaukee dominates for a reason. As for the model, I always look for brushless motors these days. They're lighter, smaller, require less maintenance, and have no friction from the brushes contacting the commutator (longer battery life?) All are advantages over brushed motors, and I can't think of a disadvantage off the top of my head.
If you're going with the hex impact, look into Milwaukee's "Surge" technology. They use a hydraulic buffer with the impact anvil, so it's smoother and quieter, with not much of a difference in impact ability...
The two drills in question are relatively new ones, made of plastic. I should go weigh the old Thor, I'd guess its 15 lbs if its an ouce, maybe more! But there's just no replacing that one - we called it "Old Grandad" for a reason. Brushless - esp. in DC motors - rules, although the Thor's brushes were in great shape 6 years ago when I disassembled it for maintenance.
Alright you bastards, I'm going to try one of these - the Milwaukee based on both this video as well as @mrblaine 's love of the brand and apparent battery availablity. My last cordless screwdriver bit the dust a year or so back...
If it doesn't work out for you, Zorba, and you just have to have a cord, you could always duct-tape an extension cord to the battery for the "old skool feel" :cool:
Reactions: L J and Zorba
I caution you with the strongest effort possible to not take one step on the Milwaukee trail. Every single person who has violated that advice has come back later and told me they really should have listened since now they own more Milwaukee cordless tools than should be legal. You are warned, do not heed this advice at your own peril.
If you aren't going to listen, then only buy the Fuel version of anything. If you will give us what you plan to use it for, I will tell you which one to get.
I have two of the Surge models. I would not trade them for anything else but if you are in situations where you just need more raw power, the Fuel impact driver non Surge has a bit more grunt. The Surge is a bit disconcerting in just how much power it has and the pure flexibility and trigger control to stop problem bits like Phillips from camming out in difficult drive situations.
My last job had people putting in fasteners non stop for their entire shift and they never had to stop for lack of a charged battery, because they each had enough to trade out and keep working.
to add to this...the technicians doing this work preferred Milwaukee exclusively. Even during the 11 years the company was owned by Ingersoll Rand and they were only being supplied with IR tools, they were doing everything they could to keep the Milwaukees (including buying batteries on their own dime), due to the superior battery life and power output. The fasteners we were driving were all DIN 7500 trilobular threadrollers into unthreaded pilot holes so it took some power to drive a 10mm fastener cutting threads in 4mm thick steel hundreds of times per day.
I spent a few weeks doing that assembly work, using 1/4" hex impact drivers, 3/8 and 1/2" impact guns, and I don't remember having to change the battery more than once in an 8 hour shift.
I'm wanting to get the 1/4" impact - as that makes sense in a cordless version for my use case. The one in the video is a 2853 "Fuel"...
@mrblaine warned me. I spent Black Friday buying way more than I should have.
Even this shit
What you want and what you are doing with it are two entirely different things and I'd rather you didn't wind up with the wrong tool.
I have pneumatic, primarily. I have a full set of tools (nearly everything they make) plus extras of Ryobi but not lithium so they are only for small jobs. I'm not going to shell out for a full new set of cordless lithium cordless tools. I haven't seen a real nail gun that was electric that didn't take twice as long to shoot nails as a pneumatic.
I prefer pneumatic tools while working in my garage. I have an airpig so I have plenty of volume at 160 PSI.
Why does there always have to be that guy in the crowd?
Try this, 3 nails per second into hard wood, zero ramp up time, and uses the common collated round head nails. I use the gold standard Hitachi Pneumatic and they have identical performance.
https://www.milwaukeetool.com/Produ.../Nailers-and-Staplers/Framing-Nailers/2745-20
I've been using the crap out of my Milwaukee Fuel impact drivers and they are the tools I've owned the longest and used almost as much as my mechanic use impacts. Not one has died yet. I have killed a few drills by being mean to them but they covered them and sent out new ones. To put that in perspective when I say being mean, I sent in a corded Hole Hawg with the two speed transmission that I blew the whole top of the case off of. Their price to fix it was more than I could buy another one for so I told them to scrap it. I don't abuse my tools but I do on occasion ask more of them than they can deliver.
Absolute musts that don't have a 110v alternative:
  1. 1/4" hex driver (used for screws and lags.)
  2. 1/2" anvil impact driver M18 (used for bolts on your Jeep, also buy an impact socket set for it. If you already have the air version you'll understand how useful this is)
  3. 3/8" drive M12 ratchet
After you have those tools report back about how life changing they are. Without those tools I'd either spend significantly more time on the job or not be able to do as good of work.
After you fall in love with those, buy the smallest/lightest M18 battery for when you need to get into tight spaces or want a lighter tool. My biggest batteries are the 8ah M18 and I haven't found the need for larger based on the tools I currently have.
Reactions: jjvw and Apparition
I've used small flush cutters for trimming zip ties. Not sure what brand they are, they are okay and we use them daily. Saw that Milwaukee has some, ordered them in, they are night and day better than the other 4 pair I have.
Thanks for that. I was using a generic pair of them from Amazon that seemed to be decent and I broke one on a medium sized zip tie. I will have to try the Milwaukee ones especially if they have a few different sizes for larger or smaller ties. Using scissors sucks and you have about a 10% chance of cutting the tie flush/dull enough to not cut you if you rub against it.
