So - how long do the batteries last before needing replacement? If you can find them?
I think in terms of years, or even decades. If I buy a tool today, I expect to be using it 20 years from now. I don't want to keep buying tools, I don't want to keep buying batteries, etc, etc. And I still don't like the weight of battery tools. It just makes sense to me to plug in anything that can be plugged in. Including my lawnmower, although I'd most likely go gas if I had a bigger yard unless I had outlets "farther out" to minimize cord length - 50 ft. of cord is fine, I'm not so sure about handling 100 ft!
From today's little job:
This drill is 50 years old if its a day - it belonged to "Elmer", and is virtually the same model 1/4" drill I grew up with - except its a model or two newer and has variable speed which my childhood drill did not. Its plugged into an outlet less than 6 feet away - why would I use a battery tool?
I have four other drills - (3) 3/8", (1) 1/2" - they all plug in and will be running 50 years from now!
