B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
You forgot bolt on bigger brakes (way bigger if you get JT / JL HD) and really the greatest improvement is high pinion. Ball joints are not any stronger than TJ and that is the weak link. 35 spline is an option for the front internal also, 32S Rubicon front outer.WMS is wider, bigger ring gear, 35 spline rear capable, 32 spline front capable, stronger unit bearings and ball joints, half the weight of a Dana 60.
