B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
You start from ride height, and set up the top of your shock such that it is your bumpstop to get your max uptravel but give you a hard stop from keeping anything on the axle or tires from hitting something you don't want it to hit. If the poly towers dont give you the uptravel you need then modify the brackets. 14" CO's are more than enough. Max droop is wherever your shocks stop or your UJ's bind or the axle goes crashing into something (like driveline into exhaust). You have to ck your droop under articulation also not just straight droop. I added limit straps, which i believe are not necessary but i liked the idea and wanted to make it racer-y.Here's where I need some help. My first question, Is too much down travel a bad thing?
I began playing with shock towers (Poly Performance) and a cardboard mock-up lower coilover mount. One side of the coilover mount will get welded to the axle tube, the other will straddle the control arm mount. As pictured, the tower sits within the engine bay with 2"+/- of height left over.
Current travel:
Bump: 22.75"
Ride height: 28.25"
Droop: 37" (disc on the ground).. I'm sure it can go more.
Poly's towers are short, compared to other manufacturers. Should I get a 2" taller tower & go with a 16" coilover?
