I have a good plan for limit strap design. I ordered the clevises, straps and some 3/4" DOM. I plan on making a bracket that sleeves over the lower coilover mount bolt & also attaches to the LCA mount. While that is on order and my sway bar mounts are being cut, I'm trying to figure out a good bump stop location.
First question (and I think @toximus said get rid of it).. Is the nitrile stop on the coilover shaft needed? I think I can make room for another 1/2" of travel and at the moment, they're the limiting factor. I'm fine with leaving them if they serve a purpose.
The picture attached shows the axle at full articulation. The laser represents the top of the axle tube @ full bump. You can see that the laser touches the top of the tube at the same vertical plane that the coilover is bolted to the axle. Mounting a bump stop at this location is about 5-1/2" away from the frame rail. For my application, can I rely on the shock body to act as the bump under articulation or do I need to move the bump stop out? I can mount the bump stops further inboard to take the weight of the vehicle under hard bump but under articulation they won't support.
