I would say you're more the exception than the rule. Many start having trouble just from a transfer case drop, which has a smaller impact, but in the same direction, as a body lift. I've had the adjustment bolt seize up on two OEM shifters so they couldn't be adjusted, and the movement of the transfer case in relation to the body made it just straight up not shiftable at all. It's always worth trying it out before shelling out the money, but I would advise planning for that possibility and be ok with having to get under the rig to shift the transfer case if there's a wheeling trip planned the day after the body lift goes on.
Also, my fuel filler hose would have been damn tight if I hadn't replaced it...might have worked, but I didn't try real hard because I was trying out the GM filler hose to get rid of my splashback issue.
