Nice! How was the ride home on the new shocks?Installed Rancho RS5000X shocks on the front and replaced my leaking radiator with a Mopar replacement. Make sure you run the self tapping fan shroud screws into the radiator before installing it. Room is tight and tough to get them started.
How hard is that to do? ... (get it working I mean) I find electrics difficult so anything more than plugging in an extension cord worries me hahaWell I didn't do it today, but I did do it yesterday. I installed and wired in a USB phone charger with a voltmeter installed on my auxiliary battery. It looks weird because I took the picture before I wrestled the carpet back in place.
Cool thanks for that...seems easy enoughIt was really easy. There are only two connectors on the back. Positive and negative. I have mine wired to a stock aftermarket switch on the dash because as long as it has power the volt meter is one and I wanted a way to turn it off when I am way from the vehicle but I also wanted it to be able to function while the key is off but I am still around the vehicle like say if I am camping or sitting around a camp fire and I want to charge my ipad.
You could hook it up to key power or battery power, but mine is hooked up through a fuse to a switch to the usb charger. So that way as long as my switch is on I have power and I can always see what my second battery voltage is. This will be good when I get my winch installed. I would be more than happy to help you if you wanted this too.
Bascially I have a power wire running from the battery to a switch. then a power wire coming from the switch to the power on the usb charger, then the charger is grounded. That is it. If you don't want to run from your battery you can run it from your key power so it is on when your vehicle is running. Not my choice, or you can run it from your fuse box since you don't have two batteries yet and just have power on all of the time but run it through a switch to turn it off.
BTW, the switch above in the picture is the dual battery isolator switch nothing to do with the USB in the picture.
clear as mud?
Cool thanks for that...seems easy enoughhaha seriously though, I like the idea of being able to switch it on and off without the ignition being on.
My kids are always complaining that there is no place to charge there phones etc...This will keep them happy...(for about a week ) haha
It is. The penguin, not so much.I also did this over the weekend. I installed my new HiLift Jack on my Dirtoworx bumper.
The jack is kind of camouflaged huh?
While we are on the subject....Penguin???? (Do you like fish, maybe ?)It is. The penguin, not so much.
Can you tell me what you did with the d-rings? I like the spacers you used, and would like to do that, only not red, you know...
Linux is an open sourced operating system based around the Linux kernal. “Tux,” is the mascot and he is a penguin.While we are on the subject....Penguin????
Ahhh ok...got it now. Understood and saved.Linux is an open sourced operating system based around the Linux kernal. “Tux,” is the mascot and he is a penguin.
Very clean install on the hilift jack!I also did this over the weekend. I installed my new HiLift Jack on my Dirtoworx bumper.
