Does Metalcloak make a good track bar?
I’ve done that but there are easier ways to diagnosis, with the full force of the vehicle on the rod end.
I can say that I didn't feel the slop on mine during a steer test like I would have expected to.
Reactions: NskLJ
Almost need to test them at all angles, as much as I hate to run rod ends on a street driven vehicle. I made a decision that I’m happy with. I was amazed how cheap that RE once I bent it and pulled it off. It’s been on there since I bought the Jeep and I think I replaced the rod end just a month before I bent it.
Shocks removed next is arm hitting the lip on the shock mount bracket. I’ve clearanced the brackets. I am very close to 50/50 and am happy with the ride.
I must have misunderstood earlier, I thought you were saying you bound up before the shocks were fully extended. I didn't bother clearancing that since the shocks make it where that doesn't happen. Though I should clean mine up to look more finished someday since after cutting out the shock mounts next to that lip there's an abrupt edge.
They have not fixed the issue and continue to send out free replacement joints rather than use a quality joint from the start.
They only gave me 1 free replacement. After that, full price.
Now, I'm running the Currie/RJ. So I have a MC track bar with a brand new, uninstalled heim joint I'll be selling when I get around to it.
  • Wow
Reactions: rasband
Measurements are in, I have a 5/8" hole frame side and a 9/16" hole axle side. What are my options other than metal cloak?
How much to ship it to me?
question, The hole metal cloak had me drill is larger than the JKS 9/16. I assume its 5/8, when I spec in the 9/16 bolt with the sleeve, there is still a bunch of play. I assume I cant Run that, because it will cause wobble? is there a way I can swap out the JKS end to fit a 5/8 bolt? So I dont have to Modify the Frame? or am I shit outta luck and have to Have a welder do some work?
This is why I went with metal cloak. PO put a RE track bar on and it was 5/8 on the frame side. If you get a currie track bar they will make the ends whatever size you want but jks only comes one way.
Just trying to figure out if I can run the 9/16 bolt. Its my daily driver, and Im sitting in my driveway. just trying to figure out if i can run the new one or not
You can't run a 9/16 bolt through a 5/8 hole unfortunately.
Guy wants to run a 9/16" bolt through a 5/8" hole on the frame wide of the front TB.
I think it's just clamping friction that holds a fastener in place, so as long as you follow the torque specs it should work, but I am open to correction. @mrblaine would know. @Mike_H would know, as well as several others who know more about fasteners.
Also, if you found a very narrow sleeve (1/16") it would work.
Reactions: Apparition
The factory TJ came with bolt slots that are 9/16" x 1.25" long in the front lower control arms. The axle is stopped from moving around with a 9/16" bolt torqued properly in that slot. If you can run a 9/16" bolt in a hole that big, running one in a hole that is slightly larger by .03" per side isn't a problem.
Reactions: JMT and Apparition
Thank you all for the clarification
