I need help finding the thread about supporting mods for every height of lift. Tag me in it please! Or let me know what I need for a 3.5 inch lift besides the shocks and springs. Thanks!
You gonna run 35's?
Assuming you're starting from stock, and doing a suspension lift, you'll need to address:
3.5 inch suspension lift with proper shocks
Track bar f/r
Sway bars front
Rear drive shaft angle adjustments/SYE
Gearing and speedo gear (not mandated but a plus)
Control arms x4 or x8 (highly likely needed)
Brake line extensions (possibly)
Upgraded brakes
Upgraded tire carrier
Upgraded axle shafts f/r (if not Dana 44)
Upgraded steering dampener
If doing a suspension lift and body lift combo, add:
Mml
Bl
Transfer case shifter cable
Relocate shifter column bezel if manual
