They are and you are looking for what is technically called an Extruded U nut.I just took a quick look. Verifying these are 5/16-18, correct?
These would work nicely.
https://www.amazon.com/dp/B0040CVQGG/?tag=wranglerorg-20
I kept the #4 Phillips. I think they can be tightened more than allen.did y'all also ditch the phillips heads? thinkin i'd rather deal with an allen key socket
This is your fault!pretty slick.
but i hope you packed um tight...... they are gonna give you a ton of shit if your jeep starts fartin brillo pads.
Always.I kept the #4 Phillips. I think they can be tightened more than allen.
That's why I used stainless. The sound didn't change from the loss of this wad. If I see another dingleberry, I'll pull it apart and see what is going on.I almost burned my orchard down using steer wool in my exhaust. In my samurai I didn’t have enough back pressure to make the EGR operate correctly. So I shoved some steel wool up the exhaust. It passed smog so i pulled the pin I installed to keep it I. The exhaust pipe and revved the engine. It shot out a long ways and by the time I found it I had a little fire burning. Lol. Be careful. Lmao.
I used stainless as well. But it gets awful hot. I like the ingenuity!!!!!That's why I used stainless. The sound didn't change from the loss of this wad. If I see another dingleberry, I'll pull it apart and see what is going on.
This is your fault! View attachment 323250
That needs to happen. I'll hang the scrubbie back on the tailpipe!Careful, some hipster might see this in Colorado and interpret it as anti-truck-nuts and it might catch on to become really popular!
The small wire will burn out in short order, I think.could you bend up a small chicken wire cage to keep it in there? even if you tacked it to the inside of the tube in a couple spots.
That's close to the arrangement I had. The muffler was too fat inside the Savvy skid and rattled a bit too much and a whole lot more after the hanger broke.
I don't want to put much money into fixing the exhaust until after the fuel cell and stretch are done. Then space won't be an issue.
6" to get to 101" from my current 95ish. The brackets will be moved along with the frame arch.How much stretch are you doing? Are you moving your link brackets or getting longer links?
So far so good?I replaced the rear main seal and oil pan gasket today. It was far easier than I expected and not unlike replacing the front inner axle seals. It's an easy job with a whole bunch of steps. I used Mopar for both. Hopefully it holds!
There was still a small drip, so I replaced the valve cover gasket yesterday. That was far more difficult than I ever would have guessed it would be.So far so good?
Cutting/lengthening the frame to keep coils?6" to get to 101" from my current 95ish. The brackets will be moved along with the frame arch.
Yes. The cut will be right behind the center skid, in front of the mid arm bracket where the frame first becomes parallel. The rear suspension stays fully intact in the frame. New crossmembers will be made to capture and recreate the two rear pairs of body mounts.Cutting/lengthening the frame to keep coils?
