Can you send me some pictures of them?They are body armor 4x4, I have the same. Really like them.
Body Armor 4x4 TJ-4121 Black -... https://www.amazon.com/dp/B000NP1PPG/?tag=wranglerorg-20@sfexeter what rocker guards are those?
Does that stay on long? I have to get my 1/2 door inners painted tan to black when I get around to painting the doors!
Let's see... a bunch of little things that have needed to be done for a while.
Still to do:
- New fan motor
- New windshield washer reservoir, pump, lines and nozzle.
- LED dash lights
- New lenses for the front blinkers
- New paddles/latches for both doors and tailgate.
- Remove and refinish center console and shifter housing.
- Remove and repaint front bumper
- Instal new front fog lights.
- Replace sliders.
- route and install back up camera.
"WE" did put it right in 1776 !!!I have been metric since 1972 but I still say "He,s about 6' " and even 8x4 sheet or 4x2 piece of timber but to tell you the truth the metric system is just so much easier! Americans say 2x4 which is strange to me because UK and its colonies always said 4x2. Your money is metric your Drugs are metric lol! They should teach kids in US school both systems, I learned both and can still use the imperial system without thinking about it, your Gas gallons confuse me though I know it was the British who robbed you of the correct liquid amounts but you have had plenty of time since 1776 to put it right!![]()
That's an expensive fix these days.
Yeah…..That's an expensive fix these days.![]()
I am going to comply with the demand for pictures... oh the shame...The front and rear pinion seals finally arrived along with the speedometer gear (37 tooth).
The 4x4 outfitter in Pataskala installed them along with the wheels and tires.
Cooper Discoverer AT3's at 31 x 10.5 x 15 on ION Matte Black 171's
I chose to have the raised white letters to the inside.
They also replaced the sway bar ends, that solved the instability I felt a few times.
Well... I finished, finally, fully rewiring a CJ7 a couple months ago while putting a modern sound system in it with a back up camera... I'm still traumatized from that so I'm going to go with the easy mechanical stuff now to get my confidence back. I have the doors off and I'm going to do the paddles and refinish the panels and the center console as well.Next?!!
8 miles is gutsy with the accuracy of that idiot light...turned off an idiot light
Let's go Brandon and Gavin Newscum too!
Bumper and fog lights after that.
I'm getting shitty gas mileage but in my experience I have ~4 gallons left when the light is tripped. I was on low E and it only took 15 gallons.8 miles is gutsy with the accuracy of that idiot light...
Had me there for a second in the first halfGit R Done !
