James & The Sahara Build Thread
BIG UPDATE!
I bought a really nice used winch today over ebay. Picking it up on black friday in south Florida. Its a Warn 9.5CTI with multimount. It comes with good wire I will swap out eventually. Its someones winch that was never used on a truck for powerline routes. Super stoked, really wanted this winch. Its a good one!!
These are the photos I've been sent, definitely looks a little used but thats ok :D.
The owner said they don't have the female end of the Warn quick power/negative disconnects so trying to figure out the best way to test the unit. I fully intend on running new wire & fusing it when I have it bolted onto my Jeep, but for testing it I need to find a way to safely connect the power/ground to my Jeep's battery :D.
Reactions: ac_ and JMT
Those are just industrial battery connectors...If you can figure out the size, you should be able to get them on McMaster-Carr or similar for not a whole lot of dough.
https://www.mcmaster.com/#battery-connectors/=1ab57oz
Getting the dimensions to order the right size is going to prove to be hard.. may have to cut the plug off and connect the wire directly to the battery terminals and tighten em down.
And again I will be running new wire and terminals/boots when I officially install it in addition to an incab winch switch. Just want to make sure I can safely and quickly test it :).
You don't need to loosen the long ones until after it is out. Those are the straps that hold the tank in the skid.
I did it just in the event I couldn't get the strap mechanism to undo at its connection point. Don't really know why I thought that may happen, but its soaked now hahaha. At least penetrating oil isn't an expensive commodity :).
Reactions: Rob5589
Its done!!
Install was relatively painless, just hate fightning the gas line fittings. Always worried I’m gonna break one. Savvy was kind enough to provide replacement nuts and bolts for the mounting points as well. The stock tj GTS is 1/16th rusted steel compared to the Savvy GTS at a beefy 3/16 aluminum. The gas tank is tucked up tight! Savvy stuff sure is easy on the eyes ;).
My cat was upset his bed was taken away from him :D
Check your shock travel. It doesn't look like you have a lot of travel before they bottom out. It could be deceiving from the pics.
What should I be checking? Pretty sure they look the exact same as when I first installed them.
The pics could be deceiving to me, like I said, but it looks like you only have 3" of travel before they bottom out. And that's ok as long as your bump stops bottom out before the shocks do.
Yeah I re-checked my bump stops when I did the axle swap a couple weeks ago. Since the install of the lift the shocks have always been my limiting point for bumpstops.
Reactions: bobthetj03
Happy Thanksgiving everyone! I hope you all enjoy time well spent with your families! I worked on putting this together last night to kinda give you guys a clear path that I will be taking the Jeep, Green is short term (~1 year from now), with Yellow being longer term (>1 year). I'm really lucky with this winch score as that's a major purchase out of the way and scheduled to drive down to Florida tomorrow!
Here are my remaining build plans:
Following finals I should be doing quite a few wheeling trips now that my TJ is finally at a stage I'm comfortable pushing it up some more difficult terrains. The sheet above is not concrete but gives you guys a good idea on my finalizing steps for her. This may change as I start camping if I want to switch to a proper RTT & need equipment. This is also subject to change if ORFAB brings back their tire carrier ;).
I consider this an open discussion so if you have any recommendations on any part of my build please share!
Ps. Beyond the great looking plan, the sheet itself is a great idea, especially with the links
Reactions: JamesAndTheSahara
