Is there such thing as a "good" performance aluminum radiator for the TJ?
I have a turbo and intercooler that yield 103 additional hp at the wheels, so that is probably pushing 300 hp at the crank. I have the Mopar radiator, A/C condenser, and intercooler radiator, all installed without removing the grill. I have no overheating problems.
Good to know. I am unable to fit an intercooler in front of the radiator due to a transmission and steering cooler sitting there but I am running a 3rd injector so that might help enough with cooling.
Mine was leaking when I pulled it out to install my AC. If you have an AC condenser good luck fitting the northern radiator without going to electric fans. Go OEM. I bought a cheap one from a parts store to get me by for a while until I have time to order a Mopar unit.
Bummer. I will probably end up buying an OEM radiator in that case.
It wasn't leaking bad yet but you could see where it was weeping out on the passenger side where the tubes enter the bottom. I was bummed to see that, then I was even more bummed to see there was no way it was fitting with the condenser.
Even though I live in a relatively cool climate I enjoy my AC on humid days. I'm not about to give that comfort up for more horsepower.
Reactions: xxdabroxx
Technically the cap doesn't leak any more than the core does. The most common leak in that area is the o-ring that is used for the seal. It shrinks when cool and expands back up when it gets up to operating temp. The leak has nothing to do with the fact that the cap is plastic, the gasket losing resiliency is the issue. I'm not going to fault Mopar too much over that since some pretty smart folks at NASA managed to blow up 7 astronauts (actually 6 and 1 civilian, but whose counting?) over the same issue.
A metal cap would have the same problem. I have watched some of the OEM radiators weep in that area for a couple of years and none have failed catastrophically due to it. They generally stop when the engine gets up to temp.
The reason it is hard to refurbish is due to the crimped connection. The metal fails or is problematic when you undo the crimp and re-crimp the new tank on with a new gasket. Some folks have reported success with taking some vise grips and crimping the tabs a bit more to slow down or stop the weeping.
I would think a cast aluminum cap that is welded to the stock core would be robust … when comes time to replace, you can reuse the caps and reweld them. This is assuming you can find a radiator shop, there’s only one I know that actually repairs radiators here in Phoenix.
The original radiator on mine had been weeping at the top and bottom seams for quite some time before the top split open. I patched the split with epoxy and drove it for a week before the replacement attached. During that week a kept an eye on the patch and noticed all the other stress cracks that were developing. I also remember being able to see the upper tank balloon as the engine warmed.
This made me wonder what the correlation was between longevity and the heat cycles with it's accompanying expansions and contractions. Would a radiator that experienced steady temperatures last longer than one with persistent hot and cold cycles. Would the difference be meaningful?
Another thing to add is the radiator cap! Hear me out … there are two types of radiator caps.
One is sealed and any heat causes pressure to start building until the valve opens into the reservoir … when it cools another valve opens to draw fluid from the reservoir back into the radiator.
Another style radiator cap doesn’t allow pressure to build unless it’s “rapid” they the valve seals and pressure builds …
Parking a hot engine with radiator cap A causes the cooling system to hold pressure long after shutdown. Cap B the hoses will feel soft and not pressurized …
Technically you refer to this as a spring vacuum valve and a weighted vacuum valve.
I can see the spring style (seems to be most common from the parts store) causing additional stress on the radiator, hoses, gaskets and basically the whole cooling system
In my experience, in the heat of the Phoenix desert, I have not found a bad radiator. All the factory ones an all 4 TJ’s/LJs popped EVERY SINGLE ONE, but they always cooled, they just weeped coolant on top. Never had an overheating issue on any Jeep, full AC, 120+ degree days, blah blah blah.
When I replaced the OEM Units
I always use a 195 degree thermostat
I always swap the fan clutch with a Hayden heavy duty
But when I was new with my first 98 TJ 5 speed. I put a 3 or 4 row copper/brass CSF. It worked, but I would see the needle dance around 210 (yes it would sway a bit). Wheeled the crap out of this thing in AZ. Fun fact, I went muddying for hours in this rig, needle was dancing more than usual, when I deep cleaned off all the mud when I got home, the radiator was just packed with mud. Killed an air filter and a MAP sensor but still didn’t overheat …
Next Jeep I got “smarter” and put a 4 core aluminum champion radiator in my LJ Ruby with an automatic. This radiator was a beast, but would run a little above 210 with stock fan clutch, heavy duty was able to overcome the resistance of the 4 cores, never overheated. I never really wheeled this one.
Next Jeep was a LJ 6 speed, I listened to the Mopar hype and bought the stock replacement. Was perfectly fine but at this point I was in San Diego, wheeling in the desert, but not as much as I did my first love, I mean first Jeep.
Next Jeep I bought to show my San Diegan wife the beauty of the AZ desert, moved back and had to make it appealing. used Mopar. Perfectly fine, never an overheating issue.
When I pick up my 5th, LJ here shortly, I’ll be putting a Mopar unless someone like Dewitt’s starts making Jeep radiators.
MORAL OF THE STORY: they all work, make sure your junk is flushed, fresh coolant, 50/50 coolant mixture (I always use G05 and distilled), 195 thermostat (I have gotten bad ones twice), fresh fan clutch (heavy duty is extra loud until it releases). In terms of absolute limits, limits beyond my experience, avoid the fancy foo foo, the 4 core copper CSF and 4 core aluminum champion seemed closer to the limit of their performance envelope, I feel the stock MOPAR had more overhead… again, overhead I never needed in the desert. If only the bastards wouldn’t crack.
In other cars/rigs if you pounding axle snapping power high centered in your favorite rock garden, take a few seconds to be kind to your rig and run your truck at higher rpm at idle to let the fan move some heat, then proceed to romp around. This also works to get your AC to chill a bit more if your stationary for a while.
I would love a real American made, full welded aluminum radiator, pressed end tanks, same core design as factory, perhaps extend the core from 1” to 1.25” tubes. Or dual 1”. Any more then that and I believe the cooling stack becomes too restrictive. But all this would do is look pretty and give me the warm and fuzzies that this might last longer than the mopar 10 year life, and possible keep me cool when the tree hugger prove they’re right and Phoenix goes up to 135 degrees in the summer.
Reactions: Zorba
My USA made CG&J fully welded aluminum radiator works fantastic…
I run the 4.0L shroud, HD fan clutch and 18” Flex-A-Light fan blade. On the 192 thermostat the Hemi runs between 194° and 197.8° or so. Doesn’t matter the temperature outside or the idle time…
The radiator has an A/C condenser, a large transmission cooler and a power steering cooler all stacked in front of it. I do run the side and bottom condenser seals (although it didn’t seem to care if they were installed or not)…
Reactions: Ericshere03
Had to Google that one … I’d say it’s worth a try … seems to hit all my points. But does it last ?!?!
I don’t think I’ve ever heard of this company mentioned before …
Been running it for several years. Best built radiator I have ever owned. And I’ve had quite a few…
They make cores for a lot of serious equipment. Heavy duty equipment that has to last. The vehicle market is almost an afterthought for them considering what they do every day…
ole thread, but ill interject.
absolutely nothing erong with the stock radiator , but under certain driving conditions, the extra capacity and cooling ( such as living in a state like arkansas, such as i do, pulling hills all the time) makes a big difference, especially if your say, pulling a boat ot trailer.
