What are you trying to de-carbon? Do you believe it to be carboned up by having driven it too conservatively?
Carbon build up in the combustion chambers is a common problem when you baby an engine too much like that. It can cause reduced performance, knocking, and/or pinging under acceleration.@Jerry Bransford my TJ almost never gets above 3200 RPM , do you recommend a carbon cleaner or should i just start revving it higher occasionally? My TJ has 80k on it
What are you trying to de-carbon? Do you believe the combustion chambers to be carboned up by having driven it too conservatively?
Manually holding the transmission in gear until the engine reaches higher rpms works fine to help a carboned up engine. Injector and fuel system cleaners or "conditioners" won't help there at all.I don't want to co-op this thread. Tell me if I should start an all new thread.
But let's say my answer is yes. If i put the gas to the floor. I am at 3200 RMPs when it hits high gear. It has an auto tranny.
Cruising at 70 I am at 2800 RMP.
Do I manually shift the trans and take her up to 4,000 every once in a while. Or, how close to redline do I need to go?
I have been running a heavy dose of Lucas in it since I got it about 2 months ago.
Thanks
That product is mostly water with a bit of ammonia added. Which is why the use of water trickled into the air intake while the engine is running is so effective at breaking up and cleaning out carbon deposits.
Techron, Cataclean or something else? Let the debate begin!
So premature detonation is no good.....Got Ya, ha.... aka premature detonation.
Water in the engine when used like that absolutely will NOT harm the engine in any way. No way no how. In fact water injection has been used in internal combustion engines since at least the 1940's which is when it was discovered how clean the engines were internally with its use. It is still used, it's even used in some jet engines. Water is injected to add power to the engine.Seafoam.
Old timers used to dribble water into the carb, which effectively steam cleans the cylinders. It works, but I'm not a fan of water in my engine.
We're not talking about dumping water into an engine that would cause hydrolock
