Well, here's the sound;
This is a 155k mile 2004 with a 4.0, auto trans, and a Dana 44 rear. From the T/C back there is a new U-joint on the driveshaft, new axle bearings and seals, new calipers/pads/rotors, new parking brake shoes, fresh diff fluid, new pinion seal, new rear shocks, new rear sway bar end links.
As soon as I get any speed this sound goes away and it drives fine. But it's annoying as hell and happens at all forward and reverse starts once it's even slightly warmed up. I can leave the garage and it's fine, but by the time I drive it 10-15 minutes I get the creaks.
Any ideas? The Dana 44 doesn't rely on a correct preload, right? Just torque. What else am I missing here? Do I need to inspect gear teeth?
