SPECWAR
Started removing my rear differential internals for rebuild.
Take a look at this super cool shot.
Those look like early flat fender turn signals. I've been thinking of doing the same.
Have any other pictures of the mounting base you made? Really considering mounting my amp there as well
What are the better solutions than a High Lift jack ( I don't like them ) , awaiting your answer pregnant with anticipation !Because most folks here have found out over the years, there are better solutions than a High Lift jack.
p.s. PM me if you need to .... wouldn't want you banded !
Finally installed my DEI fuel rail insulation kit. I was waiting to do it until I got some rebuilt injectors.
I wasn’t looking for a performance or mileage increase, but I was having an issue with smooth idle and misfire codes at idle. And I’ll say the injectors seem to have done what I wanted.
On startup, it had a much smoother and stronger idle. It used to idle rough at startup, and if I didn’t rev it a bit, it would throw a misfire code.
On my test ride, I could feel it had much better throttle feel, quicker pickup, smoother and faster exceleration. And make no mistake, it’s no race car, but it runs unmistakably better.
So, I’m happy with the results.
And the DEI kit was easy to install, and fit very well.
I bought the injectors from K Suspension, the same folks I got my Viper coil kit from. They’re 4 hole Ford, and fit perfectly, and at $120 bucks, I thought that they were a good deal. I like those guys, very helpful with dumb questions!
I bought the DEI kit after having run the Jeep hard in Sacramento traffic on a 100+ degree day for hours on end and started having heat related issues.
OEM factory bottle jack and a scrap piece of wood.
Thanks , what I use now , have two of them in fact. I have a scissor jack in my Escape that I like and I was thinking about getting one of those and welding a couple of U's on them to cradle the axle. Just don't trust the bottle jacks not to slip off.
I probably would run better without the rag stuffed in the throttle body.
