I’m happy. Maybe everything is just right. Stock wheelbase, 35’s, TT, 180% anti-squat.![]()
Did you ever do anything with those JKS shocks? Just curious.
it's probably just right because you got your springs tuned correctly
@Mike_H , I'll have to revisit your tri-shock comparison thread again, but this thread was a valiant effort. It's sad that there are not better off the shelf options for our TJ/LJ's. I'm still running the Ranchos, but the ride is not ideal with a modest bias for a stock location shock.
As far as I’m concerned, there are no acceptable off the shelf shocks for the tj. Bilstein 5100, fox ifp, rancho 9000, and accutune 2.0 reservoirs were all dog shit compared to what I have now.
Agreed, but for those that think an alignment is scary and won't go far beyond that there has to be a better recommendation than the white rockets.
Thought I would share my experience with the 5000x after adding a bunch of parts to the LJ. At first, I also had the sensation of the rear end almost floating sideways on turns, some describe it as almost like the Jeep was experiencing slight rear steer or disconnectedness. After double checking bolts and connections and driving the Jeep back and forth to work a few times I noticed that I had inadvertently left the Swayloc unlocked so that only the small anti-sway bar was activated. I flipped the selector to engage the larger bar and now the Jeep drives very differently with almost all of the extra rear end disconnectedness gone. Makes me wonder what front anti-sway bars people with the weird sensations are running. And also wondering if I missed seeing the Swayloc setting, what else am I not seeing, but that’s a different issue than shocks!
fwiw i swapped my 5000x rears for the black max shocks on saturday and i'm really fucking happy now.
5000x in front, black max in rear? Does that feel weird at all? I've been contemplating that combo since the available lengths for the BM work out a lot better in the rear of mine than the front, and the Ranchos are worse in the rear than the front.
Just the fact that you can say that, has a ton of cool factori'm going to hit up the dirt road section of mulholland drive tonight on my way home
it's a good local spot for a quick shakedown, there's enough ruts and things around to climb on to test some things out..
it would be way cooler if wasn't closed to cars between the old nike missile silo and santa maria but it's a fun little drive![]()
I also run the Ranchos in the front and BlackMax in the rear of my LJ. I have a 4 inch lift with an AntiRock sway bar and use the RS55239 Ranchos and B8528 BlackMaxs.
The Ranchos have always felt decent in the front but the rear felt like an old wagon. It would hop over every speedbump or rock. The BlackMax made a significant improvement in the ride both on and off road.
