The locker parts are pretty much non existent. So whether they can fix it is going to depend on what's wrong. Bad pump, bad air hose, hose off inside of diff are easily fixed. If the actuator inside the diff has blown, I'm not sure that is available new.
Yeah, that's not death wobble. Death wobble is when you have to go home and change your undies.
Sounds like tire balance, possibly combined with somewhat worn steering/suspension joints.
It's difficult to see the frame clearly with those pics and the poor resolution. I am always concerned when a TJ underside has bolts with black heads. Usually means that rust has been spray painted/coated over. I couldn't tell if that is the case with this one or not?
Also, do you have any pics of the engine compartment?
More and more sellers are becoming savvy at spraying an underbody and hiding rust, but usually a dead give away is the engine compartment.
Look for rusted air box clips, brake boosters usually rust in several locations, the bracket that holds the power steering pump rusts, the stock hose clamps rust and the brackets that hold the horn, the windshield washer reservoir and the cruise control all rust fairly consistently on a TJ that has seen road salt or less than desirable conditions.
I wouldn't say death wobble and not overly violent. It starts at anout 42 mph and goes away over 45 mph
Asking price was 15,999. They are willing to fix everything but won't go lower than 15,400
Thanks everyone. They sold it to someone else. Appreciate all the insight.
Bummer.
The good news is the more you go through this exercise, the more you will know exactly what to watch out for when buying a TJ and the quicker you can jump on the right one when you find it.
Don't give up...it will come along.
