thanks for this.
I need to do the same thing. I had researched a year or more ago and have put it off. I saved this from my research. SEM makes a titanium and a dark titanium that might fit the bill.
“Dash painting: SEM products for vinyl starting with their prep cleaner, adhesion promoter, color coat or classic coat, and then their low luster clear over that. the low luster clear over the top of the color coat is an identical match to the factory sheen. The color coat sheen out of the can is too shiny for those of us that are bothered by such things. The other thing that helped is if you look at the factory paint on the bezels (they are painted) it has a slight texture to it that isn't in the plastic. I put down a good couple of cover coats, then pulled back and misted a dry coat onto the cover coat so it wouldn't lay down and just give it a faint texture. It matched perfectly.“
I think I might have a manuf sticker on the back of my gauge cluster bezel that read Platinum, but like you I could never find a source for the special two tone dash bezel. Only LJ folks seems to know it was a factory package.
