Hap337 Member Original poster Joined Nov 12, 2018 Messages 42 Location Iowa Feb 11, 2019 #21 Mikester86 said: I know this is old thread, but yes, washer is necessary and torque nut to 251 N·m (185 ft. lbs.) Click to expand... Hey, thanks for the reply! Yup, I got it. Just took it into the shop and hit it with the gun, cinched it up much better! Reactions: Mikester86
M maz35 New Member Joined Feb 25, 2023 Messages 11 Location Uk Feb 26, 2023 #22 Daryl said: Get rid of that dropped pitman arm and install a stock one. And yes, that dropped arm can cause bump steer. Click to expand... Hi do you only need a dropped pitman arm on say a 4" lift ?
jjvw AI Moderator Staff Member Supporting Member Ride of the Month Winner Joined Feb 17, 2018 Messages 31,013 Location Colorado, USA Feb 26, 2023 #23 maz35 said: Hi do you only need a dropped pitman arm on say a 4" lift ? Click to expand... No one needs a dropped pitman arm on a TJ.
Jerry Bransford No Longer Participating Supporting Member Joined Nov 9, 2015 Messages 29,734 Location Fleming Island FL Feb 26, 2023 #24 maz35 said: Hi do you only need a dropped pitman arm on say a 4" lift ? Click to expand... Not even on a 4"suspension lift height. So long as it's a normal factory type steering system.
M maz35 New Member Joined Feb 25, 2023 Messages 11 Location Uk Feb 26, 2023 #25 Jerry Bransford said: Not even on a 4"suspension lift height. So long as it's a normal factory type steering system. Click to expand... Ok thank you... Reactions: Jerry Bransford
Blackjack Evil Winch Doctor Supporting Member Joined Dec 16, 2018 Messages 4,133 Location Kenai Feb 26, 2023 #26 maz35 said: Hi do you only need a dropped pitman arm on say a 4" lift ? Click to expand... Unless you are changing the mounting location of the track bar away from factory which is not needed for lifts 4 inches or under you do not need to mess with the pitman arm. Reactions: Jerry Bransford
