There are two products in that link, US Motor Works and GMB. Are they bolted or permanently attached to each other? Did you mean to buy just the fan clutch and not the water pump you're asking if you have to install?
How did you mount your accessory drive belt pully to the water pump?
It is the USMW one. I don't actually know if they are permanently attached or not.
Also worth checking to make sure there's not a buildup of debris on the AC condenser or between that and the radiator. I've had the fins clog up enough to noticeably impact engine cooling.
It all seems to be an excess stress created by the ac compressor...
The elephant still remaining in the room is your radiator came from Autozone. It's clear that it's marginal and the only fix is to replace it with something that has the required cooling capacity and an adequate cooling reserve for tougher conditions. If you can't find a Mopar, and there are still some out there, I'd at least replace it with something like a Denso... and no more store brands.
It's not as good of a choice as the Mopar where reserve cooling capacity and efficiency is concerned but if you can't find a Mopar Denso's certainly a better choice than store brands, cheap all-aluminum types, and most other aftermarket radiators.Any concerns with the Denso as opposed to Mopar? I can't find any reliable specs to look at.
@Jerry Bransford
Haven't yet replaced the radiator but I have a Denso ready to go waiting for a free weekend. Still not overheating unless I turn on the AC.
Today, the CEL came on and I got codes P00032, P00038, P00052, P00058
Is this somehow related?
Yes that works just as well for one with a manual transmission. The transmission cooler is completely separate from the radiator so it doesn't matter if the transmission cooler ports are capped off or not.The only Mopar I seem to be able to find in stock anywhere is 55037653AC which is for automatic transmission. I've heard that is fine for a manual since the transmission lines are plugged. Can anyone confirm?
Replace your O2 sensors. If nothing changes, then you're probably going to need a new PCM.
