Maybe one of these days we can paint your hood.
Noooooo!
Needs more mullet, maybe it’s singlewide material.
@RINC would run that in all the pride parades!!!!!
I don’t think he would qualify, he needs ducks for that!
Don't the vacuum hoses have something to do with the blower motor speeds?
I’ve replaced both of them along with the pigtail for the resistor. The new switch only worked on one speed too. Now that I have a new blower I’ll have to get out my multimeter and check it all out again. I replaced the resistor and pigtail a couple years back and then bought a switch from Amazon or eBay so maybe not the best option but finding one for a 97 is harder than some years
Then installed my under seat lock box- nearly lost my mind on the inbound front bolt going back in - the red are my energy suspension seat risers
Check the resistor again if the new one was used with the old motor it may have burnt the thermal limiter. You could jump across it but be careful the resistor get very hot
Where did you get those seat risers? Sounds comfy, are they? Please tell us more about it.
How much lift if a fat guy drives your Jeep?They’ll give you about 5/8 of an inch at the most
