Doggo doesn't get many car rides these days, so lifted her in and took her for a ride which she enjoyed. Other good news is I can still front squat a ~130# live load from the negative position while wearing Jesus cleats.
This twisted, coated wire was done to test a theory
on wind noise- sure enough, it works-they do this on some tower wires for that reason.
I use these on my truck ladder racks to lash loads down, going to get 4 black for the rack.
I’m happy with this 2004. It’s tight, quiet and drives excellent. Going to be a fun one. It should see some kayak trips this summer.
Got the U-joints out of the driveshaft. I had to use my ball joint press, and a 30 inch breaker bar. This was on the first "side" of the first U-joint I tackled. The 2nd "side" as well as the other U-joint could have been done with the hammer/socket technique - but that first one was NFW.
As it was, I had to work it back and forth a couple of times, plus slather it with penetrating fluid, to be able to get it to come out at all.
When I got the 2nd "side" pulled, I found my "smoking gun":
Looks like the needle bearings got so hot they fused together... (??)
Guess which cap was "the one":
Sprayed some flat black paint at the driveshaft, hope to get it reassembled tomorrow.
Old U-joints seem to be the same as the new ones.
Windshield looks a little on the dirty side for your standards![]()
I forget, why were you checking/changing them? Vibration or noise? Or both?
I replaced the battery with an Interstate from Costco. I really need to clean up some of my wiring. I think I will start with some new upgraded cables from JEEPCABLES.COM A little pricey but isn’t everything nowadays? Has anyone here used them?
Thanks,
After a really great with day @Hog ..visualizing success as usual..... We got his rock bars on and I got my 2004 dialed in- Some brake noise and new plugs. Spark plugs are funny- You’re sure you don’t need some until you put a set in, then wow.
After that my wife and I went to the Alabama Jubilee balloon festival- It was really one of the coolest things I’ve ever seen- Right until they took the Tweety Bird balloon down. Boy It was sooo over then.
Next year I’m going to bring a 22 caliber rifle with rat shot.
Those look great for target practice.
I have said this before and still mean it- get to know a forum member. Becoming friends with @Hog has been a bright spot in my life these past few years.
Here is the finale of the flipping of the rock rails.. they were on the other sides.. with the bars downward..
