Thats what I was lookin for
I will have to evaluate those options closer
Based on the above responses, guessin zinc plated
Im in the Midwest salt belt so
Thanks
I would put more faith in the quality of parts that Blaine supplies than I would for any normal retailer.
The front calipers have a coating of brake dust but the rears are still shiny.
In the image above, the axle looks wet because it has a coating of Surface Shield. If you’re going to drive your TJ in the winter, look into Fluid Film and Surface Shield to prevent salt corrosion. It should be applied to the frame (inside and out) and anything else that gets road spray.
Frame rust prevention:
https://wranglertjforum.com/threads/rust-proofing-from-road-salt.68053/
