Cant find them
Best I found were super narrow
https://www.ebay.com/itm/3145181456...d=link&campid=5337789113&toolid=20001&mkevt=1
Here are the files I used (I will need to take some new pics to show the output, don't seem to have them after all):
Tweeter pods
https://www.thingiverse.com/thing:2894802
5.25" sound pods
https://www.thingiverse.com/thing:2947831
6.5" adapter ring:
https://www.thingiverse.com/thing:3354506
The front sound pods worked beautifully, which was the main thing. It comes out in four separate pieces, basically a faceplate and pod for both left and right sides. I used plastic cement to seal the two halves of each pod together and drilled a narrow hole in the back for wires. I filled the pod itself with polyfill.
I had a bit of trouble with the adapter rings for the rear stock sound pods, but that was because of my particular speaker. They would be good in general, but I think everyone's experience with these may vary. In my case, I used Alpine Type R 6.5" component speakers (R-S65C.2). The issue with these was that they are hefty and the metal housing which holds the magnet protrudes almost perpendicular to the front of the cone (left), whereas most speakers have sharper angles (right):
I had to dremel a decent chunk of material off of my adapter rings in order to get the speaker to go through. So really depends what speakers you have. I think some people have dropped 6.5" speakers straight into the stock hole and screwed the speakers and grilles directly to the sound pod. I wanted to keep mine somewhat reversible and not mangle any stock parts more than necessary:
Can see the printed adapter rings and pods here (I will post another pic of them installed when I get a chance to take one). I had the 5.25" kicker speakers a lot of people use up front, but am about to replace with better Alpine component ones and tweeters (plan is to use the tweeter pods linked above)
i’m guessing it’s ok to wire the 4 ohm dual voice coil sub to 2 ohm while the others are running at 4 ohm, all running off of the same amp? ready to order the pieces to this puzzle, just wanted to make sure i’ve got the right pieces.
Not so clear on the actual printer itself, but can weigh in on filament. A lot of places will offer PLA and the creator of the files I linked above mentions that he used PLA and it stood up to the Texas heat, but in Australia we get regularly get days into 110+ degrees F each summer. I ended up using PETG as it has a higher heat resistance. The pay off is that it costs more than PLA. I also did it for longevity as well, because it is stronger. I think either of those filaments would work fine in Chicago. I guess read some info on the available printers and find one that supports the size you need (the rings have a wide diameter as far as consumer 3d printing goes) and one that can use either PLA or PETG.May I ask those of you with 3D printing experience what printer you would recommend thats a good product and has very versatile capacity??
Im new to 3D printing and wanna buy one now since I finally have something I want to produce
Good?? Bad?? Recommend better??
https://www.amazon.com/dp/B0B5QF985Y/?tag=wranglerorg-20
Here's the thread from the original creator of the files and includes some recommendations on the printer:May I ask those of you with 3D printing experience what printer you would recommend thats a good product and has very versatile capacity??
Beware the stereo hole can get deep fast....
Some very good advice given here.
One note though, If I'm in water deep enough to get to my speakers... I have bigger problems.![]()
Very AccurateBeware the stereo hole can get deep fast....
Very Accurate
Set a budget and expectation, and the wormhole opens and the wallet siphoning begins![]()
That is an entirely different product for an entirely different issue. I'm using those as well - but honestly don't know what they do if anything. They supposedly close the back off so the sound doesn't escape as readily in that direction, the foam rings pipe it out the front - this latter I can attest to. Still, I cut a hole in those back shells to let the speaker breathe. I figure the back shells are 90% of the $90 "pods" at 10% the cost.
I also did this to the soundbar enclosures, in addition to some boom mat and polyfill inside:
With a significant improvement in sound quality therefrom.
And I'm in complete agreement about the Marine Grade speakers - if you need them, you need them. Those who have never had to contend with a marine environment will learn quickly that its not the same as an airplane.
what did you use for the ports on your speaker pods? any poly fill inside?
So I ended up starting with the Kicker speakers everyone loves, but sending them all back.
Right now my fronts I just tried the Infinity Reference 5030 components side by side with the Kickers, and the Infinitys won. The tweeter on top of the dash provides a much better sound then just coaxials pointed at my knees
[URL][URL]https://www.caraudionow.c...#h-best-5-1-4-speaker-if-money-were-no-object[/URL][/URL]
Rear I put 6.5” Skar Audio Tx65 for now, but I have some Cerwin Vega 6.5” Im going to try now also
