Did you clean the engine block and where the thermostat sits, and by clean, really really clean it before you put on the new gasket? Make sure the new T stat hosing is perfectly flat and not warped, You may need a dab of RTV to make sure the T stat isn’t sliding down and the bolts should also be tightened evenly.
Last resort, and you *shouldn't need it, but you wouldn’t be the first one here to use some waterpump RTV Permatex 22071 Water Pump and Thermostat RTV Silicone Gasket, 0.5 oz., 0.5 Ounce , blue https://www.amazon.com/dp/B0007TQW60/?tag=wranglerorg-20
Yep, completely clean, flat, and smooth that I could tell with my finger. Used a scraper to get most of it off. Then, I took a glass scraper to get all the tiny bits off. It felt super smooth whenever I was putting it back on.
I'll use RTV or something to keep the thermostat in place tomorrow. I also got a new housing to see if the 1st housing was warped.
