The ZJ pads were not set up to use the stainless steel abutment clips that the TJ, Ford Explorer, and Liberty use. If you want to use them, grab a set of 964 pads which should come with the clips or I can send you some, install the clips, fit the pad and remove some material from the reaction bars until the pads fit nicely.
Want some clips to try?
ZJ pads are longer in the groove spacing end to end IIRC.
I have some new rear pads in a box for a tj iirc.they have the clips? The ones that go on the lower side of the pad against the slider? I'll research this some more thank you
