Refurbished the rear anti-sway bar. Cleaned, resprayed the bar and brackets black, new end links and new bushings. Wire-brushed the surface rust off the bolts and cleaned them.
Andy
Andy
Cant wait for Spring to start over here.... 6 weeks to go.
Can I get a sanity check on my order of operations.
I’m replacing my cracked radiator so I’m taking the opportunity to replace my original waterpump with a new Mopar, at which point, the cooling system will have been entirely replaced.
Should I
1) pull the old, radiator etc, install new pump and radiator and that’s it?
Or
2) use an emergency patch on the radiator, pull the fan, install new pump, assuming the patch holds, I can test for leaks on the new pump and then install the new radiator?
I’d like to avoid rework but don’t want to make the install overly inefficient.
Trying real hard to get anything done with the axle today but it's just so hot out.
I know it's way hotter in other parts of the country but this feels particularly brutal in Minnesota.
C or F?It’s 36° over here at the moment.
New bluetooth rear axle
Installed a Hayden 2771 Fan Clutch:
Please let me know it works out. I’m looking at replacing mine. Not sure if it bad or not.
C or F?![]()
