So my rear bump stops look like they need to come forward roughly an 1” to be centered and I only have a 1/2” of available threads on my lowers. With my tires on at full stuff the tires look pretty much centered in the wells. Are the stops good to go how they’re set? Or am I just looking for problem and leave them alone? Is the bump stop misalignment caused by my pinion angle from my lift and tuck and why relocating the spring perched is done?
Little backstory 06” LJ Rubicon with 35s. I just installed a new 4” RockJock lift with a Savvy tummy tuck. Working on getting it close enough to drive to the alignment shop. Lowers are set to the recommended starting pointing of 15 3/4” and there is only an 1/8” between each side measured axle to the center skid bolt hole. Pinion is set 1* degree under the driveshaft which is 18*.
