So if you have a lift kit of 4" and add a body lift of 1", does your SYE and Driveshaft length change when adding the body lift? Or do you continue to buy the SYE and driveshaft that go with the 4" lift kit?
Your transfer case and axles are attached to the frame. The body lift separates the body from the frame. It will not affect suspension lift or DS length.
You will however change the length of the rear shock since that mounts to the body. Keep that in mind.
