Kiwi TJ
Just asked myself if I’m crazy and we all said No
Flying out to the USA tonight for 2 weeks…so one last drive and breakfast before I head off
And now they're a matching setUnwrapped it's new front bumper, rear had to go back to the powder coater because it had a thin spot on the back side
Rode some trails at JeepFest and showed up some JKUs on 37s. Good day.
It feels like it took 3 hours for the first drum brake and then less than an hour for the second one.
After replacing the rear drum brakes yesterday, I got the tires on and took it out for a test drive. The parking brake works, but it is weak. When it is in gear, I can pull up on the parking brake and the Jeep won't move, but if I give it gas, it'll move.
Any suggestions on how to make the parking brake stronger?
If one side needs it, the other one does also… Replace them as a pair and also replace the swaybar bushings that attach the sway bar to the axle… low cost high gain maintenance…
https://www.amazon.com/dp/B000C57YQQ/?tag=wranglerorg-20
