Fuel Injector Tester / Cleaner Kit?
SSTJ
Lifetime Supporting Member
SE USA
My injectors are removed at the moment. Figure I should test them or perhaps clean them before I put them back in. They are originals with about 100k miles on them over the past 25 years.
I see some cheap kits online. Anyone ever use these, and have any feedback on whether they're worth the effort?
Example here.
I wonder if the spray cans put out a pressure comparable to the fuel pump, and whether that matters.
Legit Street Cars hawks one on his YouTube channel all the time...looked decent and affordable.
Edit: found it...https://www.amazon.com/dp/B07NYWH1QP?linkCode=ssc&tag=onamzlegitstr-20&creativeASIN=B07NYWH1QP&asc_item-id=amzn1.ideas.25NGH5Y6C724L&ref_=aip_sf_list_spv_ofs_m_asin
Reactions: SSTJ
I can’t vouch because I haven’t needed injector service, but have read good things about Mr Injector.
Maybe just an additive to clean? Several options. I've only done a bottle treatment.
Thanks. I'm not even sure they need to be cleaned. But I already have them removed, so thought I'd see whether there are any simple and inexpensive ways to see if they still spray well under some kind of pulse test.
Interesting. I didn't know there were places you could send them off to.
So has anyone used one of these cheap kits that I linked above, and have any feedback?
I have used WitchHunter Performance in the past for some of my other project cars.
This topic reminds me of a clip I saw of the Hoonigan boys playing around with injectors the other day. Maybe keep in mind sparks and vicinity to gas/aerosol cleaners though. Not saying this is a good cleaning by any means, but if you need to get one working now or try to diagnose a problem in a pinch...
