Finishing up my half door rehab project.
Anyone know what these are called? I'm missing 3.
Looks like the receivers for the pins on the upper doors
I've been having a problem with the Jeep pulling to the left on hard braking. Another feed on this forum recommend flushing the brakes, so I flushed the brake system today. (The Motive Power Bleeder recommend by others on this forum made this supper easy.)
Found left rear brake wasn't flowing any fluid through the cylinder. Worked with it and got it to flow properly. Finished the flush, & now no more pull to the left.
This forum has been a great source for learning how to keep my jeep functioning as it is supposed to as it gets older. Thanks to all who contribute.
(Not sure why the brake not working on the left made it pull to the left. I'll have to research that some more.)
What about vacuum bleeders? Good? Bad?
I got 3 of the 4 old bump stops out. I got 0 of the 3 new bump stops in. The springs on the lift are too close together so I'm going to have rent a spring compressor.
I did put 1" wheel spacers on and that has eliminated the tires rubbing on the suspension when the steering wheel is turned all the way.
Take it from someone who had a spring compressor pop on him. 1 year into marriage and I almost left my wife a widow. Disconnect the shocks and track bars!!!
Replaced the dead lighter with this. Interesting that it reads 11.9v and the battery reads 12.5
Tis merely a flesh wound…I also made a blood sacrifice to the Jeep gods.I was moving a jack stand around (not under load) and hit the lever to cause the bar to descend.
At least you installed yours with the text facing the right way.
When I haul the bike the disc rotors and cassette pretty much cover the brake lights and I ride 3-4 times a week, not ideal. I've had a 3rd brake light from a Chevy truck in a box for years and figured why not. It doesn't look bad at all and is plenty bright. Bonus is the left vent was almost falling out so it got fixed when it came out to run the wires.
