Most of the leaking oil is from the front passenger side of the skid plate. It’ll be jacked up on Thursday at the latest.
I don’t rcall if you have an auto and manual, but I believe the TC is ATF fluid, so make sure to check the TC for a leak.
Brake cleaner is your friend when looking for a small leak. Spray both the trans ( can I say that here) and transfer case down and let it dry. Then put some clean cardboard under it and you should be able to locate the source.
5. Let it sit like this for a few days
Yep, the transmission is definitely still leaking.
Any tips on how to track down a transmission leak on a 32RH transmission?
Throw a couple of sacks of flour on the bed and roll the tranny in it.
No, wait . . . that was a girl I used to know.
Sorry . . . never mind.
She was a tranny?
There were a couple of very fluid weekends back in college.
Don't ask, don't tell . . . at least don't ask for details.
Replaced oil sending unit on the daughter's 2004 Sport. Some mornings, the old one was not showing any oil pressure at all!
I did that awhile ago. It wasn't hard, but just annoying. because the angles were odd. Did you end up going from the bottom or the top?
Uh, yea - I think I have enough details as it is...![]()
Put the back seat back in preparation for Fridays 6 monthly inspection….fingers crossed I get a pass again
You have to have the rear seat in for inspection?
Self adhesive velcro is another way to go.
That shit is 100% GARBAGE; besides, it leaves a sticky mess on everything that is fails to adhere to.
Same w/ double-faced tape.
Even the VHB from 3M isn't going to hold up if it is exposed to UV and/or heat.
