NP231J Chain Slack
XCRN
Springfield OH
Does these seem like too much chain slack? When pulled up it hits the shift fork tower, when pulled down it does not hit case. I looked up a few videos about chain slack, they said if the input shaft was locked in place and you can turn the front output 1/4 turn while in 4wd its too loose but I dont even get an 1/8th of a turn on output.
It's going to be loose without the other half of the case attached. You are most likely fine
