"E" Trail Rated!
Note to self: Develop and insert “Zorba Rolling His Eyes Emoji” here…
For the last few months, the rig has been a bit, well...slow on the crank. So much so that the last few times I've wheeled I've been reluctant to shut the rig off on the trail. It has not left me stranded, but there have been a few times I thought it might not start. The charging system seems to be working fine.
I run an Odyssey Extreme, which has been great until now. I installed this one in March, 2000 - so it's only been in there a bit over 3 1/2 years. Since this thing is generally considered one of the best, I didn't know what else to do other than pick up a new one.
The rig is not a daily driver and does sometimes wind up sitting for long periods of time. I do usually drive it a couple of times a week, but always very short trips. Some of you know that I used to run Optima's, but along with everyone else after the Johnson Controls purchase I was only getting a year or two out of a battery - and the reason I switched to the Odyssey.
Perhaps my use pattern is causing the short battery life issue? Anyone have any insight?
Anyway, $400 clams later, it's on the bench:
My battery tray is designed for an Optima sized battery, and since the standard 34 is just a bit larger, it's not a direct drop in.
Easy to get it to fit, though. These ribs just need to be trimmed on both sides - as I did on the original:
So after just a few minutes with a chisel and mallet...
...it drops right in.
Except for the new product number, it looks exactly like the old one...
But the rig is now back to a very fast crank. Hopefully that remains the case and I can stop worrying about it for a while...
Ive actually thought of something more like this for my hard-mounted battery maintainer
[URL]https://www.amazon.com/dp/B07SLM8LT5/?tag=wranglerorg-20[/URL]
It would fit perfectly on the removable poison spider panel I have.
What air filter housing is that? I need to do something to get my IAT down so I can run more timing. I want to do the cowl intake, or cut a hole in the hood?
If you guys really wanted to get fancy,these auto eject shore line connectors are good for forgetful jeepers. Or us sleepy firefighters at 3am.
the cord pops out when the ignition is turned to start
https://www.heimanfireequipment.com/products/shore-line-disconnect
I like the cowl intake solution.
Also, can someone remind me of the dangers of a lead acid battery in a rig that goes off-road? Is it something related to danger of starting a fire? I run AGM (SuperStarter), but the cost is getting so crazy that on both my sons rigs they went with a lead acid. Everyone in my family gets good life out of them (5'ish years).
Normally, I would make fun (good-natured, my best friend is a hose-dragger) of firefighters needing such a device, but I'm guilty of backing the LJ out of the shop without disconnecting my CTEK charger, first, so the joke's on me this time! I was able to revive the CTEK by replacing connectors and re-soldering the power leads at the circuit-board level, so it didn't cost me an expensive charger. Now I route the cord into the cabin and across the shift lever...
As Rick said, all of those intake parts are from Spectre. The only minor issue is that the filter that fits is an oiled version. It works well, but does require maintenance. I do carry an oiled spare in the trailer.
I’ve looked casually for a cotton element that would fit, but no luck.
Have you checked AFE universal filters for one? Their Magnum FLOW Pro-GUARD 7 Air Filter is what I put on my Cummins after I learned the oiled type isn't recommended for dry high dust environments.
https://afepower.com/universal-air-filters
They also have "Build your own" custom filters.
https://afepower.com/build-your-own-filter
That's cool. I'll check it out. Thanks for the tip, Red.
