I think @AndyG is running OME springs !!
Old Man Emu 1.50-Inch Front Heavy Load Lift Coil Springs(97-06 Jeep Wrangler TJ)
Has anyone installed these springs?
I ran OME springs for a while and was happy with them. I looked up the springs you have listed and they show as the OME 2933 springs. Not sure why some are advertising them as 1.5". Maybe people with heavy bumpers and winches complained? Plenty of people on here have used them. Do a Google search for "Jeep TJ Forum OME 2933" and you find lots of threads discussing them.
I found the 2933's are good for 90-180 lbs and they make a 2932 which are good for 0 to 90 lbs and are .6 inches shorter. I'm only running 31s and I really don't want a 2 inch plus lift. Based on others using the 2932s, I'm thinking they will work for me with 10 mm spacer if I need. Hoping to will get around 1.5 inch lift up front with a .75 spacer in the rear.
How did the 2932 work out?
I've got 2932s up front + spacer = 2.5ish inches of lift
How much spacer and what is the compressed height of the spring?
Sounds like you're looking at a setup similar to mine. If it'll help at any point, you're also welcome to swing by and take a look. I'm just up Cooper from the Chandler airport.
Well, mine are 11 inches, and they were replaced in the last 2 years
I went ahead and installed the springs and got right around 14 inches, so a 3 inch lift for my jeep, or two inches for a “normal” jeep
