I spent the afternoon cleaning up half door components.
The door uppers got a white vinegar then Simple Green scrub all over. Then some 303 Cleaner, finished up with 303 Protectant. The driver's window has a spot that will need some additional elbow grease. There are still dirt spots in the lower channel where the metal insert pegs come through. I'm not sure how to get in there.
The panels came off and got the same scrub down. While everything dried I test-fit the driver door to the Jeep, it was pretty much plug and play. The door's top rear seal seems torn or something. It hangs out from the door, but the door still closes. I might get new seals. Not sure yet. All the internals seem to be there on both doors. The locks lock, the handles actuate the latch; I do need to get exterior handles.
Then I went to work on the panels. The passenger panel is the most bleached. It's storage pocket was also bent. I'm sure it rolled over on itself at some earlier point in its life and crushed the pocket. I figured I'd use a heat gun to attempt reshaping the pocket. I also figured I'd see what I could do with the heat gun to bring out the original color. I once saw someone discussing how to make neat welds as making a series of cursive, lowercase letter "e"s. I used that technique with the heat gun. I'd warm a large section and then start detailing with the cursive letters.
Here's the passenger before:
Here the same panel after:
Both panels after some heat gun.
I still need to deal with the bleach and gunk on the tops. I'd also like to figure out a way to refresh the interior lock/handle parts. They work, but they're really discolored. All for another day.
