others you twist of the weld nut, now that's an whole other dimension for me...![]()
<waves hand> This is not the quest you're looking for.
Go to Lowe’s, back in the area where that have cement bags. They have a very large, deep pan for mixing cement. It works great to drain transmission fluid into. You’ll have to pour it into something afterwards but it’s plenty big enough to catch most of anything.
I’ve had a couple of them for a couple decades and it helps a lot.
I don't need another thing in my garage. Pan drain plug takes up no space and makes no mess. YMMV.
I missed that you had a plug. I thought you were dropping the whole pan.
The deep pan from summit came in, and I’ve been busy with other projects so I haven’t completed my trans work yet. So we get to compare it to my cobbled together DIY solution.
For starters, the 1” filter extension is identical to the one I bought separately, although mine is machined much more nicely. I do wonder if I need a longer extension to match the deeper pan… Although the more I think about it, the less necessary I believe it is, and here’s why: The dipstick is fixed in space above the pan. It doesn’t matter if the pan is 6’ deep, “full” on the dipstick is going to be at the same distance from the valve body no matter what. So the filter extension *cant* be to ensure fluid pickup under normal conditions, or else it would need an extension from the factory. So it is most likely there to push the filter deeper into the fluid to ensure pickup at more extreme angles. But given that we know that the distance from the top of the fluid and the filter is independent of the pan depth, it should mean that an even longer extension isn’t necessary, and probably the extension isn’t *necessary* at all. A longer extension would push it even deeper into the fluid, and this handle even more extreme angles. But it seems like the problem was pretty well solved with the 1” extension.
The pans are also very similar. Same permiter shape, but about 7/8” deeper. This is probably right at the limit for what will fit under a TJ w/o a skid plate drop. The drain is also in a different location, and that may be somewhat problematic. The summit pan has the drain at the front, which is easy to get to. The summit pan has it all the way in the back, which will be covered by the skid. This means that you can’t drain the fluid w/o first dropping the skid. I didn’t realize this until just now, or else I wouldn’t have bothered with the essay on filter extensions. That drain location is probably gonna be a non-starter for me.
You said Summit push both times....
Which is the better pan in your opinion...
neither, but there's not one in the TJ pan either that I recall. Or at least if there was one it's been long gone by the time I got into the pan.
The couple times I installed new pans I just moved the old pan's magnet to the new pan.Do both of them come with a Magnet? and a convex place to sit?
Summit says they have "more than 10 available" of the RT24001. Placed my order on Friday and got a tracking # an hour later![]()
