January 15, 2017
A pile of control arm mounts begins to pile up.
And the rear arms are installed. Finally!
This may be the only time you will ever see Savvy mid arms with a factory skid. I had to cut out the corners to make room for the frame brackets. I also took measurements off of a friend's Savvy skid so I could trim the brackets to fit the skid that I don't have yet.
So far the Thrush muffler fits. I'll get pics once the skid is installed. I need to clean up all the electrical and plumbing that was connected to the old upper arms. But the Jeep is drivable. I'll fine tune the lengths and pinion and clean up some details shortly.
The handling is different. I don't feel the small impacts from the road as much. There is a bit more body roll than with the factory rear. The change is best described again as more freedom of movement. Very similar to a softer sway bar. I can see where stiffer shocks would be helpful.
I discovered that the rear does require some bump stop extension. No more than 3" to keep the rear uppers out of the tub. The spring seats also need to be relocated. Nothing lines up anymore now that the pinion has been raised.
Anyway, I'll work out how much and get that resolved soon. This change of events will most likely change what I run for springs in the rear. More on that once I get better measurements.
Speaking of measurements...
Full droop is limited by the rear sway bar.
18" between spring seats.
28" between factory shock mounts.
