Contemplating that further...more up travel would have helped. The front levered the back off the ground.How tippy did you feel in that scenario Stig? Would more up travel or more droop have improved your results?
The softer spring must compress more to support the same weight, so it has to get longer to fully unload...so it must exert down pressure at more droop.
And that is why many of us will recommend using the longest and softest coil that provides the ride height you are after.The softer spring must compress more to support the same weight, so it has to get longer to fully unload...so it must exert down pressure at more droop.
A softer longer spring that is still seated would provide more down force than just the weight of the axle alone. The longer the reach, the less "push" until there is none and the spring is free.The softer spring may droop more before unseating, but will it actually give more down force pressure to the axle?
2003 Rubicon
a 200 in. lb. spring will give more down force to the axle than a 140 in. lb. spring will, until the spring is at an unloaded state, in which case you've reached maximum usable articulation. So, the softer spring will let the axle droop further before it reaches an unloaded state, but how much additional traction did it provide you just because the tire is still hitting the ground?
Good discussion...I've just finished bolting up my rear suspension for the final time, after bumpstopping it. I'm not super happy with my shocks or more precisely, their position relative to my ride height....I'll post more of my musings in my build thread but suffice to say, my track bar hits the cross member before the shock bottoms out, and because of their position being "higher" than they should (factory location) they limit my droop. ...
At the outer reaches of their respective droops, the lighter Currie 4" spring is still pushing for three more inches after the heavier Rubicon Express spring has been exhausted. Conversely, at the point that the RE has given up, the lighter Currie is still pushing 3x it's rate against the ground. IMO, the Currie wins.
2003 Rubicon
It boils down to the environment in which you are wheeling. If I were wheeling in snow, that extra 3" of droop may have allowed me to hit ground which would have given me more traction, where climbing some slick rock would have given the droop wheel more down force, provided I didn't need that extra 3" of droop to still be touching the slick rock. BTW, I'm not arguing with you. I agree, a longer, softer spring is preferred in most situations.
This fits nicely into the discussion!
What can you do about the rear track bar hitting the gas tank cross member? Can you cut anything to get more up?
Or...
The dreaded body lift?
Or...
If the rear springs don't unseat, could you be better off adding some bump stop to allow for a longer shock?
Or...
Some or all of the above?
2003 Rubicon
Seems like your thinking in the right directions. Teraflex has a clever upper mount extension the lifts the upper shock mount 1" higher. Maybe it would be helpful. The bar pin idea can work well in some cases. I did something similar to my fronts in an earlier version of the build.At the risk of stealing the thunder from my build thread....My first instinct is use bar pin eliminators to lower the upper mount of the rear shock. That should move me more toward the middle of their travel and allow me to pick up an equivalent amount of droop. I already HAVE the body lift...that doesn't affect the position of the frame crossmember. My trackbar is hitting that thing...the member where the shocks bolt up, the front of the fuel tank skid, and two body mounts. I could also trim the offending flange to allow more uptravel. Since the trackbar is a straight rod though, trimming has its limits...I'd basically have to clear the WHOLE flange as the trackbar moves through its range of motion, so that doesn't seem like the best course of action.
I will say, I'm running the factory rear trackbar, with a relocation bracket. The body lift DID prevent that bracket from contacting the tub, so I did gain some amount of uptravel with the BL, just not much.
Since the usuable travel exists between the bump stops and the free length of the coils, how do you select a shock based on its compressed and extended lengths?
2003 Rubicon
I don't have a rear track bar anymore, so I can't help much there.We need to address the TB before selecting the shock, unless we are going to make the TB the limiter.
