So have anyone on here used the M.O.R.E. kit? I think the steering sounds like a good addition.
The pucks are aluminum, so the debate about "plastic" vs. homopolymer form of acetal, squishy vs. non-squishy, how long before it squeaks, etc. can be put to rest. I really want to use see if there is a negative to the M.O.R.E. kit other than I will lose 1/4" of height over the newer kits from Savvy and BMB, Which may be significant, but I don't know at this point until I start the belly-up.
Been running the MORE from when there were the only choice and it has done exactly what it is supposed to. If I were to do it again since there are choices now I would run a BMB with a MORE steering bracket. That .25 inch does not seem like a lot but for things like tummy tucks it does make life a bit easier.
