Consider a turbo.
Or both a stroker and a turbo. =)
Hi jeepers
I have LJ 2005
Regear 4.56 .wheel 33.12.5R15 with left kit 3inch manual 6 speed transmission
Planning to purchase stoker engine 4.6 stage 2 from Golen
Please looking for feed back on this engine or is there any other recommendation
Regards,
I have a Golen stroker and there are several others with strokers on 33s (@SkylinesSuck and @Rickyd for example). Its a good upgrade from stock (around 25% increase in RW hp/tq) but not as powerful as you might think based on Golen engine dyno numbers. Advantages besides the power are:
1. Ease of swap (pretty much bolt in).
2. Stock cooling system still works well.
3. Probably cheaper than crate V8 swap (even though still expensive).
4. Your stock drive train is fine.
Disadvantages are:
1. Less power than you were hoping for.
I have details of my install, driving impressions and stock vs stroker dyno results in my build thread;
Stroker Dyno Results are in… and they are not what I hoped for:![]()
After 600 miles on the new engine, it had its first oil change and I headed back to the same Mustang Dyno the original 155K 4.0 was measured on in June when the motor made 136 hp and 168 ft.lbs. This calculated to represent a 24% drivetrain loss vs Jeep’s stock crankshaft numbers (181 hp and 222 ft.lbs). The now installed 4.6L stroker made 280 HP and 320 ft.lbs on a SuperFlow engine dyno in May. That was with no accessories, a holly stand-alone EFI system and an open header. I supposed Jeep may have used similar...
Good luck!
Disadvantages are:
Good luck!
Titan is popular in the Sunshine State
https://titanengines.com/jeep-strokers/titan-high-performance-jeep-stroker-engine-4-6-4-7/
run in to flat tappet cam failures
Be aware many many folks in the States run in to flat tappet cam failures now days, myself included. This is not a function of it being a stroker motor (or jeep motor specific even), but many strokers come with high lift cams and stiff valve springs. Nobody has definitively figured out the root cause, but that fact likely makes the issue worse. Be sure to properly follow break in procedures using correct oil. It also might be worth mentioning it to Golen when you order and see if they have any input or recommendations if you think it's a concern (and it should be).
I did consider a turbo. The thing that waves me off is cooling issues in the TJ platform. I'm aware plenty have had good success with V8s or boosted stock motors in trail rigs, but clearly you have to do right and not everyone does. For a lot of street driving (including the kind I do) cooling is probably less of an issue. But for trails (Moab for example when your ambient temp gauge says 120 deg, and your creeping along with no airflow) high power density motors worry me a bit.
That's the leading theory, but boutique high ZDDP oils haven't solved it. Some people blame bad cam cores, some crappy lifter quality, some narrow cam lobes. I am having an Oldsmobile big block built for Grandpa's car. The builder has seen several cam failures as well and isn't sure why when they worked fine for years. He only builds roller lifter motors now. Unfortunately it's not an option for us.
This is the leading reason why I stopped considering a rebuilt motor.
Zinc content in oil perhaps? Or is that just a handy explanation/excuse?
Just by virtue of the fact there are so many stock 4.0s running around, it would seem they live longer. My stock 4.0 ate a cam lobe though (which started me down my engine modding journey) back in 2003 so it isn't fool proof.
