It looks like there is enough material on most of the ports to blend them some.
At this point I'm going to wait for the new exhaust manifolds to arrive before I try anything. Then if the new ones don't fit/work I'll look at trying to make these flow better.
Is there a comparable set of manifolds from later hemi's?
OK, so I guess that we all suspect that Big Brother is watching and listening to everything we say and do, but this just might be another confirmation of that. I get this article today out of the blue from Speedway motors on headers vs manifolds....
Coincidence..?? Or maybe they are..
Either way I've included the link and it might be a good read, most of theirs are pretty good..
Shhhhhhhhhhh......
https://www.speedwaymotors.com/the-...utm_medium=sms&utm_campaign=campaign_10447542
Transmission Update
In case you missed it in the earlier post about it, the 545RFE and 65RFE are considered "modular" transmissions. While most transmissions can be converted from 2x4 to 4x4 configuration, many needed to be disassembled in order to do so and many needed new/modified output shafts. The 545/65RFE is different; going from 2WD to 4WD is simply a matter of bolting on the correct tailshaft housing/extension.
[Factory 2x4/RWD tailshaft of the 2012 65RFE I'm using for my swap]
[Removal of 2WD tailshaft extension]
Removal requires nothing more than removing the 15mm socket bolts around the perimeter of the adapter, then using a small rubber mallet and a putty knife to break free.
[4x4 t-case adapter installed]
Both the 2WD and 4WD extensions are installed with Black RTV. My transmission-rebuilder friend (the one who gave me the extension for free) suggested "Ultra Grey" since the black will sometimes weep. When a trans rebuilder for 20-years suggests something, you do it!
[Output shaft stickout w/t-case adapter installed]
[Output shaft stickout; edge of shaft to t-case mounting surface]
[New overall length of 65RFE w/4WD t-case adapter installed - nearly exactly 27"]
You wouldn’t have happened to write down the part number of that extension housing adapter. I was looking at my 2nd 545 and my 231 and it it easy to see something else is neededI spent some time searching but came up empty.
Will do. Thank you very much.
Wildman,
I used a 24134L for the upper hose and a 21047 for the lower hose.
Upper I got through Rock Auto
Lower I got on Amazon: https://www.amazon.com/dp/B000C2UAGU?tag=wranglerorg-20
Sorry for the delayed reply, I didn’t see this until now. This is a very crude pedal bracket I bent in a vice but it’s been working great with no issues. I recently acquired a 75 ton press brake and when I get some free time I’m going to tighten up the bends and clean up the designHammer do you happen to have any pictures or drawings of your fuel pedal bracket? Be nice to have the information here plus I'm starting my Hemi swap and need to make or find a bracket.
Thanks
Sorry for the delayed reply, I didn’t see this until now. This is a very crude pedal bracket I bent in a vice but it’s been working great with no issues. I recently acquired a 75 ton press brake and when I get some free time I’m going to tighten up the bends and clean up the design)
